SOLO VIDEO Youtube [MOTORI]
Messaggio da Mick Doohan » mercoledì 26 dicembre 2007, 17:13
non avete visto le piegatubi da oleodotto ... :asd :asd
il paradiso del tecnico idraulico .... :ride
Mick Doohan on EP3 & Pandemonio a CH4: http://www.spritmonitor.de/en/detail/533789.html
RobyVTEC
Messaggio da RobyVTEC » mercoledì 26 dicembre 2007, 17:52
....il fratello di quello postato da luporum :sifone
specRR Dark Lady
Luporum
Messaggio da Luporum » mercoledì 26 dicembre 2007, 19:59
Biggest Front Shovel Excavator, Aurora Oil Shale Mine, Canada
With a huge 2,223,000 lb use-weight, the O&K RH 400 built in Germany the biggest front-shovel-excavator world-wide . It was presented in 1997 to the public in Dortmund officially.
This colossus of two 16 cylinder engines is based on directly-injecting turbo-diesel-aggregates from the Cummins company. These two engines of the type QSK 60 are developping power of 4398 HP together. In order to start up these two monstrous motors, the RH 400 is equipped with six 24V/510Ah car-batteries. The maximum output of the engines is reached at 1800 r.p.m. and these are supplied from one 4228 U.S. gal grasping fuel-tank. With these huge figures and the patented Tri-Power geometry, the RH 400 develops a shovel-encouragement-strength from a brutal 711,000 lb. The shovel-volume of this giant corresponds to a payload of 189,000 lb which amounts to 57 yd³. The hydraulics-system is supplied of a 3435 U.S. gal grasping tank. If it depends on it, the 18 hydraulics-pumps are in the position to pump 2642 U.S. gal oils per minute through the cylinders with a work-print of 4495 psi. Consequently, the RH 400 reaches cover-performances from up to 17,778,000 lb/h. The outer total-impression of this giant is just as huge. It is 32'1" wide and from the roof of the driver-cubicle down to the ground measures it 33'4" high. And with its 36'1" long, 10" high and 6'6" wide chains, the RH forces a traction force of over 889,000 lb.
Since 1997 only 6 of this gigantic earth-moving-machines built and shipped to America. Five of them work in a mine in Canada and one in the USA.
RobyVTEC
Messaggio da RobyVTEC » giovedì 27 dicembre 2007, 17:57
Terex Demag übergibt Riesenraupe
8. Oktober 2007
Artikel versenden
Der Terex Demag CC8800-1 Twin – der weltgrößte Raupenkran – wurde an den neuen Eigentümer Al Jaber übergeben.
Der CC8800-1 Twin bei der Übergabe
Aufgrund seiner Tragkraft von 3.200 Tonnen nennt der Hersteller den CC8800-1 Twin den „weltgrößten Raupenkran“
Auf dem CC8800-1 aufbauend, verwendet der Twin eine Doppelauslegerkonfiguration, um die Tragkraft zu steigern. So kommen imposante 3.200 Tonnen Tragkraft zustande. Das maximale Lastmoment liegt bei 4400 tm.
Key specification
CC 12600
Max. lifting capacity at 22m radius (t) 1,600
Max. load moment (tm) 39,000
Max. boom length (m) 234.0
Luffing jib (m) 120.0
Max. counterweight + central ballast 470t + 160t
specRR Dark Lady
streetracer
Messaggio da streetracer » giovedì 27 dicembre 2007, 19:18
ma ke è fantascienza? :shock :shock
http://www.rotaryheaven.net/
Messaggio da Mick Doohan » venerdì 28 dicembre 2007, 10:19
streetracer ha scritto:ma ke è fantascienza? :shock :shock
no, esiste tutto un mondo di macchinari fuori scala che noi ignoriamo ...
typer558
Messaggio da typer558 » venerdì 28 dicembre 2007, 14:09
sonny Vti
Messaggio da sonny Vti » venerdì 28 dicembre 2007, 15:46
DiegoVTEC
Messaggio da DiegoVTEC » venerdì 28 dicembre 2007, 16:57
sonny sono stupendi qst :ride :ride :ride :ride :ride
shining
Messaggio da shining » venerdì 28 dicembre 2007, 19:58
Attenzione! ho trovato il genio! e il migliore che abbia mai visto!
il premio 2007 va a lui
guardate attentamente, e cercate di capire come fa a vedere quanta benzina ce nel serbatoio
http://fishki.net/comment.php?id=29781
shining
Messaggio da shining » venerdì 28 dicembre 2007, 20:03
ho sbagliato sezione :imba
be, ce un camion....
streetracer
Messaggio da streetracer » sabato 29 dicembre 2007, 18:54
ma ke imbecille :shock
RobyVTEC
Messaggio da RobyVTEC » sabato 29 dicembre 2007, 19:33
Ma luporum che fine ha fatto? :sosp
Speravo avesse qualche altro "coniglio nel cappello" :(
specRR Dark Lady
Messaggio da manzo » sabato 29 dicembre 2007, 21:25
il week end di solito è via :D
Shogun
Messaggio da Shogun » domenica 30 dicembre 2007, 16:59
ma questo non è dal telefilm "malcom"? :sosp
Messaggio da Mick Doohan » domenica 30 dicembre 2007, 19:42
Luporum
Messaggio da Luporum » lunedì 31 dicembre 2007, 15:13
RobyVTEC ha scritto:Ma luporum che fine ha fatto? :sosp
Che tenero che ti sei preoccupato... :imba
Sono stato a festeggiare l'ultimo dell'anno in anticipo... :asd
Comunque seguite questo link...
http://search.alice.it/tools/service/im ... b06f_o.jpg
e cliccate su:
The World's Biggest Machine "Chews Up" a Bulldozer (pictures)
e guardate che fastidioso pezzettino di prezzemolo che si è incastrato tra i denti...
:asd :asd :asd
EDIT: Purtroppo ho visto solo ora che questo mezzo è stato costruito dalla KRUPPS... della Thyssen...
Se lo avessi saputo, avrei evitato il link. :(
Ultima modifica di Luporum il lunedì 31 dicembre 2007, 15:31, modificato 1 volta in totale.
Messaggio da psico86 » lunedì 31 dicembre 2007, 15:25
RobyVTEC
Messaggio da RobyVTEC » lunedì 31 dicembre 2007, 17:48
e cliccate su:
:asd :asd :asd
Puerca vaca :shock
specRR Dark Lady
Messaggio da DOK85 » giovedì 10 gennaio 2008, 14:08
Chi c’è in linea
Visitano il forum: Nessuno e 0 ospiti
